Re: john deere # 8sickell mower parts
Bob
Jim, up through serial # 50,000, the seal was a part of the roller bearing cone (cone part # JD8903H).
At serial # 50,001, it changed to the seal # you posted (AH15738) and a different bearing cone (part # JD8187A).
The bearing CUP part # stayed the same (JD8225A)
Surf over to www.jdparts.com and jump through a few hoops/drop-down menus and you can download and/or print the parts catalog. (.pdf format)
And, as I posted before, check your serial number before buying the seal or the bearing with ATTACHED seal.
