(quoted from post at 19:08:02 08/23/14) These bucket spears are a PITA.
it carries the bale to far ahead of the loader(weight issue) and you can't see a damm thing cause of the bucket.
Do you self a favor and build a dedicated 2 prong bale fork( pallet fork style)pinned to the loader arms.
(quoted from post at 20:10:35 08/23/14) I have been using one for years now and the only problem I ever ran into with it is the bottom of the bucket peeled out so I had to fix that. Big thing is making sure you have enough weight on the 3 point to off set the loader and bale weight. Sure as heck easier to use then removing the bucket and I use the bucket as much as the bale spike and it takes all of 5 minutes to change out
tupid is as stupid does.(quoted from post at 14:33:24 08/23/14) With pallet fork style, [b:2198b927eb]be careful on tipping the loader up and
raising high, the bale can tumble down the loader arms and
crush the driver.[/b:2198b927eb] There is nothing holding the bale in place.
Need a bracket to stop that from happening, a tall shield bar.
Paul
