Ted McAlister
New User
This message is a reply to an archived post by Shawn W on December 29, 2012 at 17:35:34.
The original subject was "New Holland 852 baler".
This Model Baler I had around me for 15 years and I can tell you the maximum size bale it makes weighs 1500 LBS. There is a special lever on the machine if you have a rope running from the lever to inside your tractor's cab you could then pull to make the baler make smaller size bales. One thing I can suggest is make sure those two main chains that carry the bars are well greased because after 10000 bales if they are not greased well they will break and you will have to take all the bars off and get new chains and some other parts replaced.
