Roto-cycle Shredder
Martin, Get them off the shredder go to your local farm stores and match as closely as possible those blades to the new ones similar shape, size, length. hole diameter should get you close! Your local JD, Case-IH, Ford/New Holland will have a selection of blades and bolts too!
Hope this helps!
Later,
John A.
IIRC Roto-cycle mowers built by the now defunct Perry Co,Waco,Tx didn't have swing back blades but had 5-6 ft long blades with a cutting edge on each end.
You are correct. Belt driven and very tough, but the metal usually rusted through prettty quick. Don't see many around any more.
