new holland 650 auto wrap round baler
foxhoun
I am looking for a complete pto shaft for the 650 round baler.I am sure I can get one from new holland
but I am trying to find one a little cheaper.The ujoints are fine but there is some play in the shaft its self.
Any help will be appreciated
Thanks Foxhoun
Gotta watch that. I put the pto shaft from my spreader on the baler when the joint went up one afternoon. NH makes their baler shafts out of time by 90 degrees from most shafts, so I had to take it easy to keep it from shaking like all hail. What I did do was replace the front and rear half of the shaft with two new ones that were in the same time as the spreader from the cross forward. MAKE SURE the new front section is NO LONGER than the old one, or you will start beating the carrier bearing behind the joint up on turns and up angles.
