Fast hitch parts
Need front side bearing gaskets...anyone have them? Ever made them? Part number pa24896
Also need some bushings...part numbers 651219r1 and 651501r1.
Also wondering if anyone has some grease fittings and caps...part number 109353.
Any help in this restoration is much appreciated.
Lance, Parts Depot show several of the bushings, part # 651219R1 and 651501R1. You have to go thru your Case/IH Dealer to get parts from Parts Depot.
No luck so far on your other numbers.
Bill
Lance, PA24896 gasket. Could that be made from gasket material or spread on a coat of form-a-gasket ?
109353 shows 1/8", 30 degree elbow zerk. Dealer or Parts Supply Store hopefully could match that up by the description ?
Bill
Isn't that just a standard grease fitting? Think there might be some in all the fittings I have that I have no use for, I know some are 45* but some might be 30* that come in assortments. I use loads of the straight fittings both 1/8" pipe thread and 1/4" 28 thread sizes but to get them I had to buy the assortment with fittings I cannot use. I also have very little use for 90* fittings either.
Yep...I got the wrong number. Looking for the steel caps.
Your numbers worked too. Ordered some parts from my local ih dealer.
