24t pickup chain
nisse
I broke the pickup chain on my 24t, I went to the local fleet and farm store and matched up with what they had and A2050 chain looked correct. I installed it and it works ok except it starts skipping in heavier hay. I looked in the parts manual and it specs AP22463H chain, do I need different chain?
Thanks,
John
If the links 'fit',you have the right chain.As was said,tighten the idler sprocket.Take the slack out of it.
Thanks for the replies, I moved the idler and it seems to be better, but will be a while before I can test it, managed to finish first cutting with it slipping a little.
Thanks,
John
