I was able to experiment with my 10 wheel v rake yest on about 6 acres of grass.. when opened up all the way would combine two swathed rows into one. I wanted to be able to rake the two swaths still but not into one large row but two side by side rows with space in between so as to run baler up one side then back down the other.. Worked well once I figured out the combo. I have a 10 wheeled sitrex cart rake so you know what Im working with. What I ended up doing was taking the two rear wheels off and replacing them with the single wheel from the front. It would still reach the edges of my swaths and raked two rows perfectly instead of one large row. Basically I made a 6 wheel rake that raked two rows into two baling rows at one time...
