TractorLinks.com
Re: NH 68 square baler making long bales sometimes.
old
08-14-2014 10:49:57
The measure wheel is either sticking at times or lack of hay under it is making it so it does not turn as it should. You may need thicker windrows because lack of hay as in small windrows can cause that also
Tx Jim
08-15-2014 12:17:04
 Re: NH 68 square baler making long bales sometimes. in reply to old, 08-14-2014 10:49:57
Please explain how a thin windrow will cause a sq bale to be longer than what baler is set for.
Shealray
08-15-2014 16:14:19
 Re: NH 68 square baler making long bales sometimes. in reply to Tx Jim, 08-15-2014 12:17:04
Thank you all for your help.
I value learning from many sources.
It takes a village.
old
08-15-2014 14:09:07
Simple lack of hay to fill the chamber. Not going to argue with you so please do not argue with me. Keep this site a nice place to be
Tx Jim
08-15-2014 14:23:27
 Re: NH 68 square baler making long bales sometimes. in reply to old, 08-15-2014 14:09:07
No argument from me just facts: it takes hay traveling through chamber to turn measuring wheel to raise arm to the slot to engage trip dog.
Simple explanation: no hay coming in chamber,no measuring arm movement,no bale created short or long.
old
08-15-2014 14:32:13
 Re: NH 68 square baler making long bales sometimes. in reply to Tx Jim, 08-15-2014 14:23:27
On my 271 a small windrow does in fact cause bales that are long so hey that is why I say what I say and I will NOT see you answer if you do. Please since we can not get along do not answer my posts
Tx Jim
08-16-2014 05:29:20
 Re: NH 68 square baler making long bales sometimes. in reply to old, 08-15-2014 14:32:13
old
The only reason we don't "get along" is because I don't believe everything you state and you do't like it when someone disagrees with you. All I politely asked for stating PLEASE was an explanation. I see in no way how wanting the "correct information stated" harms this wonderful very informative forum.
Good Day,Jim
Shealray
08-15-2014 16:12:58
It take a village.
Shealray
08-15-2014 11:48:01
Star is turning well think the teeth on the gear need to be fixed.
Also hay not packed tight to make lighter bales for us old people to pick up.
Thak you for the help
KEH
08-14-2014 15:29:28
The metering wheel insert can wear the trip arm so much it won't engage the metering wheel. Had that happen on a NH S 77. I welded up and ground down the trip arm until it engage the metering wheel again. Lasted as long as I kept the baler.
KEH
rrlund
08-14-2014 16:17:43
 Re: NH 68 square baler making long bales sometimes. in reply to KEH, 08-14-2014 15:29:28
If memory serves me right,there's a spring that holds the arm in against that wheel too isn't there?
Shealray
08-15-2014 11:43:06
 Re: NH 68 square baler making long bales sometimes. in reply to rrlund, 08-14-2014 16:17:43
Yes I have a new one just have not put it on. I will do that.
Thanks
