TractorLinks.com
NH 68 square baler making long bales sometimes.
Shealray
08-14-2014 10:11:53
My little NH 68 square baler is making good bales using my Ford 5000.
Once in a while I get a long bale.
Any ideas why?
How can I correct this?
Thanks for the assistance.
david1
08-16-2014 18:13:19
 Re: NH 68 square baler making long bales sometimes. in reply to Shealray, 08-14-2014 10:11:53
I was buying some hay years ago and were getting bales out of the top mow. The farmer tossed me a shorter than usual bale and said " the baler was looking out for him". So in a while he tossed down a longer than average bale. " I said looks like the baler was looking out for me".
Shealray
08-17-2014 09:00:39
 Re: NH 68 square baler making long bales sometimes. in reply to david1, 08-16-2014 18:13:19
What was good for one is not good for the other who is right?
Always the view is in the eyes of the beholder.
I love your story thanks for telling it.
Bret4207
08-14-2014 15:20:40
The metering wheel uses tiny grooves to move the arm upward till it trips.They fill with rust, dirt, mud and they simply wear. This year I had to grind the little nub that carries the arm over the wheel back about 1/8" and file new grooves in mine. They'd simply worn away giving my odd sized bales. No long bales now.
Shealray
08-15-2014 11:42:07
 Re: NH 68 square baler making long bales sometimes. in reply to Bret4207, 08-14-2014 15:20:40
Super I will do the same.
Thanks
Bill VA
08-14-2014 14:46:17
What length bale are you trying to make with your NH68 and how long are the long bales?
Shealray
08-15-2014 11:45:48
 Re: NH 68 square baler making long bales sometimes. in reply to Bill VA, 08-14-2014 14:46:17
We need light bales around 40 lbs. We are not young and need all the help we can get. So short and tight maybe. Long one was twice the lenght of shorter. About 3 1/2 feet long for the short ones.
Short
Donald Lehman
08-14-2014 14:27:20
Sometimes with our old S-77 baler, you would get a big slug of hay the last plunger stroke before tying and you would get a long bale. The next bale would be correspondingly smaller. The Super 77's were notorious for that. Not sure about the 68's though.
charlie n
08-14-2014 11:13:21
There 's a small friction wheel on the metering shaft.It makes contact with the trip arm.It can be worn to the point that it will slip.Look to see if the trip arm has a smooth edge.That will tell you if you have slippage.Easy fix.
I'd start there.Good Luck.
old
08-14-2014 10:49:57
The measure wheel is either sticking at times or lack of hay under it is making it so it does not turn as it should. You may need thicker windrows because lack of hay as in small windrows can cause that also
Tx Jim
08-15-2014 12:17:04
 Re: NH 68 square baler making long bales sometimes. in reply to old, 08-14-2014 10:49:57
Please explain how a thin windrow will cause a sq bale to be longer than what baler is set for.
Shealray
08-15-2014 16:14:19
 Re: NH 68 square baler making long bales sometimes. in reply to Tx Jim, 08-15-2014 12:17:04
Thank you all for your help.
I value learning from many sources.
It takes a village.
old
08-15-2014 14:09:07
Simple lack of hay to fill the chamber. Not going to argue with you so please do not argue with me. Keep this site a nice place to be
Tx Jim
08-15-2014 14:23:27
 Re: NH 68 square baler making long bales sometimes. in reply to old, 08-15-2014 14:09:07
No argument from me just facts: it takes hay traveling through chamber to turn measuring wheel to raise arm to the slot to engage trip dog.
Simple explanation: no hay coming in chamber,no measuring arm movement,no bale created short or long.
old
08-15-2014 14:32:13
 Re: NH 68 square baler making long bales sometimes. in reply to Tx Jim, 08-15-2014 14:23:27
On my 271 a small windrow does in fact cause bales that are long so hey that is why I say what I say and I will NOT see you answer if you do. Please since we can not get along do not answer my posts
Tx Jim
08-16-2014 05:29:20
 Re: NH 68 square baler making long bales sometimes. in reply to old, 08-15-2014 14:32:13
old
The only reason we don't "get along" is because I don't believe everything you state and you do't like it when someone disagrees with you. All I politely asked for stating PLEASE was an explanation. I see in no way how wanting the "correct information stated" harms this wonderful very informative forum.
Good Day,Jim
Shealray
08-15-2014 16:12:58
It take a village.
Shealray
08-15-2014 11:48:01
Star is turning well think the teeth on the gear need to be fixed.
Also hay not packed tight to make lighter bales for us old people to pick up.
Thak you for the help
KEH
08-14-2014 15:29:28
The metering wheel insert can wear the trip arm so much it won't engage the metering wheel. Had that happen on a NH S 77. I welded up and ground down the trip arm until it engage the metering wheel again. Lasted as long as I kept the baler.
KEH
rrlund
08-14-2014 16:17:43
 Re: NH 68 square baler making long bales sometimes. in reply to KEH, 08-14-2014 15:29:28
If memory serves me right,there's a spring that holds the arm in against that wheel too isn't there?
Shealray
08-15-2014 11:43:06
 Re: NH 68 square baler making long bales sometimes. in reply to rrlund, 08-14-2014 16:17:43
Yes I have a new one just have not put it on. I will do that.
Thanks
