Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Stuck PTO shaft. My way to fix the problem
old
08-13-2014 18:59:20
So a few months back I had a guy give me a 3 sided PTO shaft that was stuck tight. A few days ago some one was asking how to get one freed up so I figured what the heck I would free this one up just for fun.
#1 poured ATF on to and into for a few days. #2 Cut the safety shield off ya some will say not good but there there for the guy who does things the wrong way. #3 took a 4 ton port-a-power and chained it to the shaft in such a way it would push out on it and used a torch to heat it being careful not to heat up the port-a-power cylinder.
Well that is all it took to free it up. It is laying on my shop floor right now in 2 pieces so I will clean it up lube it up and put it back in service
showcrop
08-18-2014 09:50:20
 Re: Stuck PTO shaft. My way to fix the problem in reply to old, 08-13-2014 18:59:20
I hope that there is no one running one of those big old NH balers with thrower that is not familiar with the scalping danger.
old
08-18-2014 13:06:57
 Re: Stuck PTO shaft. My way to fix the problem in reply to showcrop, 08-18-2014 09:50:20
It fits a brush hog which is one piece of equipment NO ONE should even get of of a tractor with the PTO engaged. But either way guards are made for those who do stupid things
showcrop
08-14-2014 17:33:50
Don't they say that 90% of the people who got injured by PTO shafts knew that they were stupid and went ahead and worked on the equipment anyway? Or is it that smart common sense people just get in a rush once or twice in their lives? Of course there is always the stray grand kid who you thought was still in the house, but who wants them around anyway?
Ken Macfarlane
08-18-2014 06:51:23
 Re: Stuck PTO shaft. My way to fix the problem in reply to showcrop, 08-14-2014 17:33:50
We leave shafts on stuff that runs when stationary like post hole digger.
Who is going to get around something like a tedder pto shaft while running? The teeth are right there spinning ready to take your legs off.
old
08-14-2014 17:39:30
I do not run machines when kids are around that is just flat out a NO NO and one should know if they are out there any how. Way to easy to have a rock get thrown out from under a brush hog and kill some one if they are out in the area your cutting so again goes back to common sense and knowing who what and where and knowing one should NEVER get off a tractor with the PTO spinning
Ellis Kinney
08-14-2014 14:45:02
I finally took the plastic safety shield off of my LandPride 35-90 because it was nearly impossible to grease and lubricate the sliding shaft. Ellis
DoubleR
08-14-2014 06:52:51
I have one of those 3 sided shafts on a post hole digger. I ended up hooking the digger on one tractor and hooking a chain on the end of the pto shaft with another tractor to get it apart.
Now every time I park it I pull the shaft apart until I use it again.
2x4
08-13-2014 20:48:51
did you check the ends to see if it was put together right? My 3-sided shaft has 2 sharp corners & one flat corner. They must go together matching up the corners but they can be jammed in wrong & that's when they get stuck.
old
08-13-2014 20:52:33
 Re: Stuck PTO shaft. My way to fix the problem in reply to 2x4, 08-13-2014 20:48:51
As I said a friend gave it to me that way so I do not know if it was right or wrong but it was stuck
Bob
08-13-2014 20:33:35
GOOD job!
And, thankfully, a new plastic safety shield kit should be readily available, and somewhat reasonably priced!
Texasmark1
08-16-2014 05:23:48
 Re: Stuck PTO shaft. My way to fix the problem in reply to Bob, 08-13-2014 20:33:35
Yeah, $50. I priced one for my NH 404 hay crimper, not for safety, but because it was picking up the cuttings and wrapping them around the shaft. The safety shield can be anchored in place and prevented from turning.
But did you know that you are supposed to grease the interface where the locking nylon ring on the shaft meets the shield.
I am afraid of shafts and do not have anyone around when working. It only took a couple of cartoons of accidents that can happen to convince me that you do not come near a rotating shaft...........period!.....same thing in clearing a clog in a round baler. Shut the tractor off. Only takes a second and only takes a second for you to be in some other land.
Mark
old
08-13-2014 20:54:23
I'll not replace the shield many things of say 50 years ago did not have them and to me they are only made to make a stupid person safe
Bryce Frazier
08-14-2014 06:43:26
 Re: Stuck PTO shaft. My way to fix the problem in reply to old, 08-13-2014 20:54:23
I'll second that. Stay out of the way and use a little common sense! Bryce
supergrumpy
08-14-2014 05:12:51
Amen
