Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: JD 350 sickle mower on a Kubota B7610
GarryinNC
08-12-2014 18:28:56
I think that the B7610 is not enough tractor for that sickle mower. In the Kubota line you would need to be in the L series of tractors for a better match up. I have a 350 mower and use it behind a Kubota M4030. The mass of that cutter bar in the grass and cutting will probably pull your 7610 around to the right. Your tractor weighs about 1,400 pounds and the additional weight of the loader will help some. When mowing with a sickle mower, it will not mow in a turn. You have to square off the turns and raise the bar and back up or raise it and do a 270 degree turn to mow down the next side. That probably did not make very much sense, I know! Some operators on larger tractors lock the brake on the inside wheel to make a fast turn while the cutter bar is still in the crop. I have never had that work very well. I realize that you only have a couple of acres, so you might get by with your combination.
There is a Kubota dealer on here with the handle of jm, you might post a call out to him and see what he thinks. He has a lot of Kubota knowledge. You do have a very nice tractor.
Garry
