Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: JD 350 sickle mower on a Kubota B7610
Bob
08-12-2014 15:05:09
I don't know why you are calling it a "kick back bracket", it is simply part of the cutterbar lift mechanism.
2 things... first you need to swing the drawbar to the side so it is NOT directly under the PTO shaft, then you need to set up the lower chain so it holds the mower frame the correct distance above the ground and stops excessive lowering of the 3-point.
THEN you set up the upper chain so the cutterbar lift works correctly as the 3-point rises.
You REALLY need a manual, as it details all these steps.
All that being said, I hope it's not a nine foot mower set in the wide position, because I have one on an IH 424, a tractor twice as big, and that's plenty of mass flopping around behind my bigger tractor.
cityboy
08-12-2014 15:18:41
 Re: JD 350 sickle mower on a Kubota B7610 in reply to Bob, 08-12-2014 15:05:09
Drawbar does not move side to side.
Maybe this mower does not fit on my machine, which is a 2003 or 2004 model year.
Thank you.
Roger in Iowa
08-12-2014 19:02:10
 Re: JD 350 sickle mower on a Kubota B7610 in reply to cityboy, 08-12-2014 15:18:41
Drawbar has to move to the side or it will not work properly!
Copyright © 1997-2015 Yesterday's Tractor Co.
