Hydraulic Cylinder Capicity
DoubleR
Location
Mid Mi
I'm looking at ordering a new cylinder for my 8 Ft. I.H. transport disk from ASC.
The one I'm looking at has a 1 1/16 rod. with an 8 inch lift. Retracted length of 20 inches 2500 psi.
My question is, is it big enough to lift the disk up and down without blowing the seal or something else. The one I have been using on it has an 1 1/8 rod on it.
A standard 8"stroke 'farm' cylinder is what you need.3" is more than adequet for that small disk.As was said,"rod size' has nothing to do with it.
When you say a 3 inch will lift it are you talking 3 inch bore? Is that what I need to refer to when looking at them?
I can look at one in front of me and tell what I need. Its hard to tell when looking at a picture of one on-line though.
Rod diameter has nothing to do with lifting force, and everything to do with overall cylinder strength. 1-1/16" is probably the smallest rod diameter you should consider.
(quoted from post at 13:27:13 08/12/14) When you say [b:cf4da10a56]a 3 inch will lift it are you talking 3 inch bore?[/b:cf4da10a56] Is that what I need to refer to when looking at them?
Yes.
A cylinder with a 3 inch bore at 2200 PSI oil pressure will lift 15000 lb.
The thinner the rod the more chance of bending it.
A cylinder rod of the same dia when used in vertical position can handle more weight without bending than when it is used horizontal
FORCE (weight of Implement) = AREA of RAM/PISTON x PSI/Hydraulic pressure
Force=Area x PSI
EG. Disk/ Forcec(10,000 lbs) Area of 4" Ram(3.142xR2)=3.142x2x2=12.568 x 2500 Hyd/psi=31,420 lbs
4" ram with an area of 12.568 Square Inches x 2500 psi would lift 31,420 lbs 31,420/2000 =15.710 Tons
If my math is incorrect I apologize
Bob........
A 3"x12" is the standard lift cylinder on a small disc. I doubt the 8" will have enough stroke to fully lift it unless you rearrange the mechanism to account for the lack of rod length.
Rod
(quoted from post at 07:23:30 08/13/14) A 3"x12" is the standard lift cylinder on a small disc. I doubt the 8" will have enough stroke to fully lift it unless you rearrange the mechanism to account for the lack of rod length.
Rod
Most tandem disks I've seen/used required an 8" stroke cylinder not 12".
Just to agree with the others, a 3 inch bore is the common hyd cylinder all implements are designed to use. The rod size isn't so important, other than the manufacturer has more or less confidence in the steel materials he is working with and will make the rod a bit bigger or smaller.
And yes there are many cases where a special cylinder is needed, bigger rod for a side or extreme compression force, etc. but not on a common disk or implement use.
Paul
