TractorLinks.com
Homemade foam marker
Charllie in MO
08-12-2014 04:00:05
Was looking for a good, cheap way to make a herbicide foam marker. Any help will be appreciated.
Charlie
lyle1020
08-12-2014 18:44:32
 Re: Homemade foam marker in reply to Charllie in MO, 08-12-2014 04:00:05
BUILT one years ago 2 gal gas can each side tire valve pulled in to inflate sump pump line over spout to end 100 lb propane tank for air and a ball valve got to put smalltee valve in to limit air supplie have used over many 100s of acres
Charllie in MO
08-12-2014 19:29:07
 Re: Homemade foam marker in reply to lyle1020, 08-12-2014 18:44:32
Thank you very much, btw about how many psi do you use from the propane tank?
Charlie
MBOROMAN
08-12-2014 06:44:56
Here is what I read Take a plastic gas container with a pour spout Drill an appropriate size hole for a valve stem from a tubless tire in the bottom. Connect a 12v air compressor such as used for
floats,balls,etc. Slip some sort of hose over the pour spout and
route it to the discharge point.
A personal thought-put a sock like thingee over the end of the spout to make it ball up instead of
drizzling.
If anyone tries this,please let us know
Charllie in MO
08-12-2014 19:30:27
 Re: Homemade foam marker in reply to MBOROMAN, 08-12-2014 06:44:56
Sounds like it should work, thank you very much.
Charlie
