Trying to Find Rims
Anonymous-0
Does anybody know what vehicle or impliment wheel might fit the trailer I have? It has F&H hubs with the number 106749 cast in them that are 6 lug with a 4 1/2" center and from center to center of lugs are 3". I thought I had found some but they are 2 1/2" not 3. It's a real heavy duty trailer but the rims are shot. So I need 4 plus a spare or two.Any help would be appreciated I'm going to make it my tractor hauler. Thanks.
It is is a flat bed trailer of some sort good chance it has the Chev, Toyota, etc type rim.
If you get the nontrailer rims you will most likely have to cut the center hole bigger to go over the hub of the trailer axle. but keep it tight enough that the hub carries the weight not the wheel studs. Just did this last week for a farm trailer I am building.
up until now I thought all 6 bolt were the same had a 1932 Chevy 6 bolt wheel that would fit my 1977 4X4 Jimmy also would fit the 6 bolt MAZDA B2000 as well no Idea where you got a smaller 6 bolt rim from. the web site with short cut will give you a listing of 6 bolt usage on cars and trucks.
Ypop
poke here
Thanks for the replies. Yea I thought all 6 lug was the same also but there apparently not. Thats why I was so happy when I found those on the curb with good tires and a free sign on them but they wouldn't fit. The trailer is a flatbed and looks professionaly built.I measured the bolt pattern yesterday across and it was 6" center to center. All I see on the web is 5.5. Oh well I've been looking for years I guess the hunt continues!
