Rotary cutter operation question?
Should the rotary cutter (Bush hog) deck be level or be lower in the front when cutting heavy weeds and grass?
I have a 5 ft cutter and in heavy weeds/grass it pulls my TO35 hard.
I always sharpen the blades as much as possible before starting to cut my crp land.
I lower the rear wheel so the cutter will cut as high as possible. The only other cutting height I have is raising the lift arm set height.
I only cut the areas with weeds.
I see others cutting all the crp land and cutting it low, but they have much bigger heavier equipment.
