NH Superhayliner 69 Pickup Guide Wheel
walterfd
New User
Does anyone have the dimensions for the pickup guide wheel for the NH Superhayliner 69? I need to replace the rubber tire on this wheel. Most all of the rubber is gone. Thank you.
NH has only used two pickup gauge wheels in the last 70 years or so. The one you are lookng for and a pneumatic 15x600x6. If you get next to any NH baler with a solid rubber wheel, it's the same as you need.
3.00x12.
http://www.ebay.com/itm/New-Holland-Baler-Gauge-Wheel-/271566824359?pt=US_Heavy_Equipment_Attachments&hash=item3f3aa4e3a7
I just measured the pick-up wheel on my NH68 and it's 12 inches in diameter and about 2-3/4 inches in width. The wheel is somewhat worn and it is solid rubber-ish material.
Bill
Thanks charlie n, the wheel in the link you included is just like mine. But, I am looking for the dimensions so that I can pick up a new replacement at NorthernTool, Harbor Freight or maybe online. Even better would be buying just the new rubber. Can't find it. Nothing wrong with my wheel. I measured from the axle out to closest rub point and 12" would clear but not by much.
Bill Va, thanks for the measurement. I found a 12" flat tread on Amazon for $30 with a poly wheel (850lb capacity) that looks closest to the old wheel and tire.
Thanks to you all for you quick help!!
