Row crop cultivator
I need to find a 6-30" cultivator now that I am on narrow rows. Old 4-38' is a Dakon with danish tines. Need to be able to flow some trash as I don't plow anymore. What do you guys like best, danish tine or C- shank and what brands. Thanks.
Back in the early 70's I switched to 6 row narrow like you and had a 4 row wide front mount on my Oliver 77. Found some additional sweeps and hangers and made it into a 6 RN. Worked good.
Too bad you aren't closer to n/w WI - my cousin's JD 6rn is still sitting at my place. He used it one year (bought used), then enlisted in the Air Force. Now he works in OK, and will probably never use it again. Would be nice to get it out of here...
I haven't cultivated since I switched to narrow rows, but I mostly used a danish tooth when I did cultivate.
IHC cultivators are good either Danish tine or C shank. White also had a good cultivator. Buffalo has a great minimum till cultivator.
