Belly sickle mower for AD WD
Farmallb
Can anybody tell me where I can get a pitman rod, and V belt for a belly mounted 7ft AC sickle mower??
ALSO, Anyone know where I can get a manual for how to mount it?
There is probably a manual on eBay if you look. You can log onto www.agcopartsbooks.com as a guest and search for the parts manual. Find the belt # and Google it. Someone will be selling it and give the dimensions of it. As for the pitman, you may have to find another mower and use it as a template. Not sure anyone is making them for the old AC's.
AaronSEIA
Thanks for the reply. As for finding another mower for the pitman. IVE N E V E R seen another AC sickle mower under OR behind. Guess ill have to make one.
My Dad bought a new AC mower for under the WC (1946) but I don't think it would fit a WD. You may have to make a pitman yourself if possible.
you are going to have to have a model number for manual. I have never seen a belly mount mower for a wd,, side mount yes not belly mount. Rear mount mowers are #7 and 80r models. Most tractor part websites have a universal pitman stick.
AC had a model 3 rear mount with a pitman that fit WD and others. #7 and 80R are Twin Wheel Drive, no pitman.
