Re: Dearborn Lift-E disc
Anonymous-0
Hey Guy's: Anyone here know if a Dearborn Lift-E disc has a round or square gang axle shaft? Also need to get a new bearing spool . Have one gang that has a broken cast iron bearing spool and a slightly bent axle. Tom G. from Wisconsin fixed me up with a replacement bearing half, so I am good on that part.
Thanks
Longbowsteve
Maybe you should take it apart first so you can see EXACTLY what you have and what you need to order.....Ordering parts before dissasembly is dangerous.
