JakeBrakeIH
I just recently went through and replaced all the wear parts on my c-20 plow but I wanted some advice on making sure my coulters are set correctly. Is the center of the coulter supposed to be directly above the tip of the point? Do you have it set, so the coulter cuts slightly to the left of the shin(if sitting on tractor)? The coulters themselves are worn but about how deep are they supposed to cut?
I know so people dont like them, or cause a lot of trash build up but just doing some plow days etc and would like to have them on and work as intended. Thank you in advance!
