Hi,
My baler isn"t tying well and I have discovered that the shaft that runs the tying mechanism is loose inside of the main shaft that runs the apron chains. Is this supposed to be a solid shaft that runs through the larger shaft that the apron chain sprockets are bolted to, or are the 1 1/4 inch solid shafts on each end, pressed into the larger shaft? I looked on the New Holland website at the parts book and it shows it as one piece.
I have removed the shaft from the baler but the loose end will not come out of the larger shaft. It seems like it has a shoulder on it that has been pushed in too far.
Thanks
Thanks
