I just picked up a 5' Farm King brush mower for behind my MF TO35 tractor. I've never had a brush mower so I'm not sure how it should be set up on the 3pt. It has a tail wheel which can be adjusted for height of cut and I'm guessing I would set the 3pt to match so the mower is riding more or less level?
When I go down in dips or up over things it tends to bottom out. Someone had fashioned some crude wheels for the front of it which I removed because the shafts (two long bolts) had bent. My guess is that they are best suited for mostly level ground.
