Anonymous-0
Hi:
I have just acquired a 270 Hayliner and I have some questions on its performance.
I have the unit running and putting out bales but I noticed that the string on the chamber side is longer than the wheel side. The bale hold together but is bowed (I think because of the slightly longer string), can this be adjusted?
Also I need to replace the wheel on the chamber side as the one on there is weather cracked and will fail. Can the axle be adjusted out to accommodate a wider wheel. Any ideas as to the approximate weight of these balers?
Thanks
PaMnd
Thanks
PaMnd
