vermeer 503i baler
charlie89
New User
This is my first post let me know if I do
something wrong anyway here we go I have a
vermeer 503i round baler and it will not bale
it starts a small roll then when it gets about
12 inch diameter it hangs a against the flat
roller and stops rolling. I can not understand
this please help
I have a 505 super I, and the only thought that comes to my mind in your circumstance is to check and see if a shear bolt is broken on the drive/starter roller. Mine was doing that one time and the shear bolt was broken, but had just enough bolt to start the bale, but then as the bale grew larger, the broken piece of bolt was not enough and it would allow the shaft to spin. I put in a new bolt and have never had that happen again. I'd guess 10,000 bales or more and no problems. Worth a check.
Thanks thats probably the only thing I havent looked at ill look tomorrow and let you know how it turns out
