I recently bought an 8n ford. After some hunting, I finally found a 501 sickle mower to go with it. The mower is in great shape. A couple of new bearings, new belt, new pitman rod. I've had it about a month, but finally got time to hook it up. It has a clamp for each arm. That was simple enough. It came with its own toplink, with a large spring attached to it. I got everything hooked up, and the PTO shaft was too long. It "possibly" could have been hooked first, then the arms, and toplink. I feel certain that it would still be too tight. It would be easy enough to cut the PTO shaft down. I'm just pretty sure that would be a mistake. The PTO shaft looks original to the mower. The PTO shaft coming out of my tractor appears to be covered by another PTO shaft. Could that be the issue? I'm confused.
