Case IH 8465 baler slip clutch discs
BMerritt
New User
How do I go about R&R the slip clutch discs on a case IH 8465 round baler? It has (HAD) 4 friction discs and the parts depts are saying the part 709711087 comes with one plate (I forgot what he thought it was) and two discs so I'm ordering two units I imagine.
Thanks for any help so I don't take the entire baler apart.
I can't just buy 4 separate friction discs somewhere is what I really want to ask.
Here's a picture of my 8465, it has 1 plate & 2 friction discs.
To r&r the clutch undo the bolt on the output shaft of the gearbox, in the 1st picture. Then take off the chains in the 2nd picture. Then in the 2nd picture take out the bolts on the large plate the holds the bearing for that shaft and you can slide the shaft to the right and redo the clutch. Good Luck with it.
