IH mower guys, I need help
300guy
I have a C-24-P mower and need a part for it. The part number is 451 458 R1 which is the main frame pivot plate. It is about 26 inches long, 6 inches wide, and has a 90 degree bend in it. When the bar catches on something, this plate pivots back. It is bolted to the main frame that the flywheel shaft goes through. I twisted mine this past week and I am not sure it can be straightened. GRRRRRRRRRRRR! And you have to dismantle the entire mower to get that plate out!! Double GRRRRRR!
Parts Depot show it. You need to go to your Case/IH Dealer so he can call them and order it for you if they still have it.
Bill
Yes but they have that listed as a "spring", so my dealer is having them do a visual check. Thought someone here might have a good used one.
