Yesterday's Tractor Co.
Shop Now View Cart
Re: Pro Quality Hay Basket set up
07-12-2014 12:54:17
We got a Forage King basket over 20 years ago so I have a little experience.There was a kit to relocate the hitch under the bale chute if you were using a New Holland baler.We had a 268 and later a 315 and the new hitch fit both.If you are going to unhook the basket alot you will want a "jaw" type hitch where you can pull a handle to open the hitch rather than trying to hammer the pin out under pressure every load.The only time we ever had much trouble turning was when baling straw but it can happen in hay as well.The weight of the bales in the chute adds to the resistance from the tension adjustment so definitely start off with less tension.I liked using short dense bales to minimize breakage.This might work well for you too.I remember stacking grassy hay on the wagon as a kid and the grass would sometimes be slippery enough that a string would pop off over the corner of a long bale.
