Yesterday's Tractor Co.
Shop Now View Cart
Re: Sickle Mower advice needed
07-11-2014 06:01:16
I have never had or seen a balanced head work, used lots of bar mowers with pitman with absoulte no problem, don't see what could be advantage og a balanced head except mowing down a ditch bank or clipping tree limbs along side a field. What you will get is a very heavy lift to raise any 9' bar to transport so unless you are very strong you may not be able to do it. 7' was all either Dad or me could lift. We had an Oliver 3 point 7' pitman bar unit but the way it was made you could trim those trees with it but the way it was designed it was equivilent to a 9' bar and it took both Dad and me to lift that bar to transport position. And I think a semi mount will follow the ground better than a mounted. Also a 9' may not go in your storage shed where a 7' would. For a 9' you need at least a 11' probably a 12' door to get it in to store. And most rakes were designed for a 7' swath and some will not work good trying to split a swath.
