Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Help ID this Disc
Mike Aylward
07-09-2014 07:38:53
Appears to be a John Deere KB. I notice it has no scrapers. It would ball up in a heartbeat around here without them. Mike
Tx Jim
07-09-2014 08:24:49
 Re: Help ID this Disc in reply to Mike Aylward, 07-09-2014 07:38:53
Mike
What's the differences between a KB & KBA? How can you determine from photo it's a KB not a KBA? I know KB is an older model than KBA.
Thanks,Jim
JD Seller
07-09-2014 20:24:57
 Re: Help ID this Disc in reply to Tx Jim, 07-09-2014 08:24:49
TxJim: The KBAs around here where newer and where wheel lift. Terrible disk for ridging a field.
Leroy
07-10-2014 05:40:21
 Re: Help ID this Disc in reply to JD Seller, 07-09-2014 20:24:57
I had both the KBA drag and wheel carried and set properly they DID NOT ridge, something was wrong if they did. That was thw last pass before planting disk while the McCormick was more the primary disk but both were used in both places when there were 2 of use to do the disking. Pulled the drag type back of the wheel type many a time.
Tx Jim
07-10-2014 03:19:19
JD Seller
Are you implying KBA's were lift type only? If so that's incorrect as there were drag only KBA's. KBA's are newer than a KB but not the other models I mentioned. If you think a KBA ridged bad you should have tried getting a RW or RWA to level the soil. Now I'm talking BAD.
Mike Aylward
07-10-2014 06:56:40
 Re: Help ID this Disc in reply to Tx Jim, 07-10-2014 03:19:19
We used RW disks for years without any ridging problems. You just didn't want to drive in the same place all the time. That holds true for any disk. They were a good disk for a lighter disk. Mike
Tx Jim
07-10-2014 03:24:06
TIMnMD
Can you find and post some casting numbers from the disc in the photo? If so I'll try and ID the model. My curiosity is wanting to know. As Mike stated it's probably a KB
Thanks,Jim
TimnMD
07-10-2014 12:14:26
 Re: Help ID this Disc in reply to Tx Jim, 07-10-2014 03:24:06
Sure can. I will get some numbers tonight and post them.
Mike Aylward
07-09-2014 10:52:23
Jim, the reason I called it a "KB" is because I have sales literature for "KB" and "KC" disks and it is identical to the pictures of the "KB". The "KC" has wider blade spacings. To be honest, I am not sure of the differences, either. I am looking through my information to find them, if they exist. My guess is that the main difference is in the gang bearings. The older disks had somewhat lighter bearing housings than the later ones (white iron bearings). Mike
Mike Aylward
07-09-2014 11:07:45
 Re: Help ID this Disc in reply to Mike Aylward, 07-09-2014 10:52:23
Also, I believe the older disks had lighter spools as well. The disk pictured has the lighter spools on it. Mike
