Yesterday's Tractor Co.
Shop Now View Cart
Re: Baler capacity and acres/hr or better tons/hr.
07-08-2014 20:46:06
I don't think I'm running the pickup too low, it has a gage wheel and I set it so the wheel is about a 1/2 inch above the ground.
What you describe is exactly what happens. Auger rises up to its stop, then stops turning when plugged. Usually it happens when there is a clump in the windrow or if the row is just too wide, or if the hay is too dry and it just builds up in front of the auger but will not go under it.
Ken Macfarlane
07-09-2014 07:18:16
 Re: Baler capacity and acres/hr or better tons/hr. in reply to dmiller, 07-08-2014 20:46:06
The raking has to be reasonably even but the 336 is pretty forgiving I find.
Sounds like your auger belt is loose or worn/glazed. Sometimes the pre-compressor tines aren't set right either and lets the hay get away from the pickup teeth at the top.
On the edge of the pickup near the pickup transition to the auger area is hay catching? If it starts to catch there clumps will jam so the auger can't haul it away.
