TractorLinks.com
Re: vermeer 504 super I belt tracking
Determined
07-08-2014 19:47:05
Sounds like you are not getting hay across the width fast enough when starting a bale.
Too much in one corner at the start and the belts will walk over and flip.
If you are working with a light windrow you need to hit it on a angle with a bit of speed and weave side to side right away to get things started properley.
If a belt flips shut down and eject the part bale, right the belt and try again. Easy enough to roll out the part bale and pick it up once you have a bale started.
Light windrows suck for starting a bale, if you can, start a bale on a decent row then move over and pick up the light stuff.
Check your lacing daily and stay on top of it and you won't be fixing in the field as much.
