Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Help ID this Disc
TimnMD
07-08-2014 17:48:03
Bought a couple implements from a local gentleman and he offered this disc for free if i was willing to dig it out of the hedgerow and haul it away. No tag or name anywhere i can find but all the casting # start with KK. Its in good working condition but don't really need it as i have an IH disc already. Any idea on value?
Thanks Tim
TimnMD
07-10-2014 17:45:31
 Re: Help ID this Disc in reply to TimnMD, 07-08-2014 17:48:03
Tx Jim
I found a couple casting numbers.
On the pivot where the draw bar attaches is KK4416 and on the spool where i assume the bearings are is KK4645B
Thanks Tim
Tx Jim
07-11-2014 03:55:47
 Re: Help ID this Disc in reply to TimnMD, 07-10-2014 17:45:31
KK4416 & KK4645B are part numbers for a KBA built up to 1953 but not PN for a KB
TimnMD
07-11-2014 17:27:10
 Re: Help ID this Disc in reply to Tx Jim, 07-11-2014 03:55:47
TxJim
What is the difference between an KB and a KBA? I think i am going to hang onto the KBA and my IH. Haven't got to try the JD yet but i am a sucker for old iron.
Thanks Tim
Tx Jim
07-11-2014 17:49:42
 Re: Help ID this Disc in reply to TimnMD, 07-11-2014 17:27:10
Without do a lot of research I know the KB is older model plus I think it is lighter especially the white iron brg's & disk shaft spools.
TimnMD
07-11-2014 19:02:08
 Re: Help ID this Disc in reply to Tx Jim, 07-11-2014 17:49:42
Thanks for all the information.
Tim
MLD
07-10-2014 09:40:44
Looks like a JD KBA to me, they do a nice job. I'd say it's worth $200-300 bucks. It will cost you that to replace the scrapers, I did on a KBL.
showcrop
07-10-2014 04:55:19
I used to have one of those. I finally figured out that it wasn't worth my time and fuel to drag it around.
Leroy
07-10-2014 05:43:02
 Re: Help ID this Disc in reply to showcrop, 07-10-2014 04:55:19
You bust have been trying to do with it what they were not designed to do and that is go out in unworked field and get it tore up, they werer designed to finnish a plowed field. And they were the best disk ever made for that.
Mike Aylward
07-09-2014 07:38:53
Appears to be a John Deere KB. I notice it has no scrapers. It would ball up in a heartbeat around here without them. Mike
Tx Jim
07-09-2014 08:24:49
 Re: Help ID this Disc in reply to Mike Aylward, 07-09-2014 07:38:53
Mike
What's the differences between a KB & KBA? How can you determine from photo it's a KB not a KBA? I know KB is an older model than KBA.
Thanks,Jim
JD Seller
07-09-2014 20:24:57
 Re: Help ID this Disc in reply to Tx Jim, 07-09-2014 08:24:49
TxJim: The KBAs around here where newer and where wheel lift. Terrible disk for ridging a field.
Leroy
07-10-2014 05:40:21
 Re: Help ID this Disc in reply to JD Seller, 07-09-2014 20:24:57
I had both the KBA drag and wheel carried and set properly they DID NOT ridge, something was wrong if they did. That was thw last pass before planting disk while the McCormick was more the primary disk but both were used in both places when there were 2 of use to do the disking. Pulled the drag type back of the wheel type many a time.
Tx Jim
07-10-2014 03:19:19
JD Seller
Are you implying KBA's were lift type only? If so that's incorrect as there were drag only KBA's. KBA's are newer than a KB but not the other models I mentioned. If you think a KBA ridged bad you should have tried getting a RW or RWA to level the soil. Now I'm talking BAD.
Mike Aylward
07-10-2014 06:56:40
 Re: Help ID this Disc in reply to Tx Jim, 07-10-2014 03:19:19
We used RW disks for years without any ridging problems. You just didn't want to drive in the same place all the time. That holds true for any disk. They were a good disk for a lighter disk. Mike
Tx Jim
07-10-2014 03:24:06
TIMnMD
Can you find and post some casting numbers from the disc in the photo? If so I'll try and ID the model. My curiosity is wanting to know. As Mike stated it's probably a KB
Thanks,Jim
TimnMD
07-10-2014 12:14:26
 Re: Help ID this Disc in reply to Tx Jim, 07-10-2014 03:24:06
Sure can. I will get some numbers tonight and post them.
Mike Aylward
07-09-2014 10:52:23
Jim, the reason I called it a "KB" is because I have sales literature for "KB" and "KC" disks and it is identical to the pictures of the "KB". The "KC" has wider blade spacings. To be honest, I am not sure of the differences, either. I am looking through my information to find them, if they exist. My guess is that the main difference is in the gang bearings. The older disks had somewhat lighter bearing housings than the later ones (white iron bearings). Mike
Mike Aylward
07-09-2014 11:07:45
 Re: Help ID this Disc in reply to Mike Aylward, 07-09-2014 10:52:23
Also, I believe the older disks had lighter spools as well. The disk pictured has the lighter spools on it. Mike
Tx Jim
07-09-2014 03:47:41
 Re: Help ID this Disc in reply to soundguy, 07-08-2014 17:48:03
Ditto on JD Model KBA
TimnMD
07-08-2014 19:49:07
My other Disc is an 8' IH #37 in great condition. I really only need 1 disc so any opinions on which is better? For now only use in a 1 acre garden and 1 acre of sweet corn. Thanks for all your help.
Skyhighballoon(MO)
07-09-2014 21:08:02
 Re: Help ID this Disc in reply to TimnMD, 07-08-2014 19:49:07
Keep the IH37. I have a 10'9" IH37 I use for field work often. You can still get bearings, spools, etc for it. I also have a JD one identical to yours with most (but not all) of the scrapers. It got used on a plow day about 6 years ago but has sat since. Mike
DeltaRed
07-08-2014 21:43:50
Keep the IH.It has wheels,so you can move it around.The JD,not so much...
Leroy
07-08-2014 18:24:35
KBA John Deere and depending on location $500 range.
Leroy
07-08-2014 18:26:30
 Re: Help ID this Disc in reply to Leroy, 07-08-2014 18:24:35
6 blade means 7'6" max cut on back gang and very good disk.
DeltaRed
07-08-2014 18:17:45
John Deere.Look for the JD logo on the cast parts. A similar disk sold at auction last year.Brought $200.00
