TractorLinks.com
Re: Tying
Dick2
07-08-2014 05:17:39
Have the manual with you when you check out the needles, knotters, twine tension at each phase of the tying process. Usually something is out of alignment, a pin has sheared (or partially sheared, which is harder to find), or a bent or worn part is throwing the timing out of whack.
Each piece has to be checked and compared against the knotter that is tying as you cycle the needles and knotters through the tying cycle. Eventually you should see the problem.
Good luck.
