Need opinions of a JD 275 disk mower
Randy G
I'm going to be looking at a 2008 JD 275 9' disk mower. I've never used a disk mower before. Would like to know the reputation they have and what to look for. What would also be a fair price to pay.Would a 2510 gas be enough to run it? Thanks in advance!!
RG
Check amount of slack in gears between each cutting head. Be sure all cutting heads turn freely. I'd guess $5000. Your 2510 should pull it but no run away with it in thick grass. I've pulled a 9 ft disc mower on a 45 pto hp tractor but it was on a caddy
I run a NH 262 7 ft disc mower on a 2510 diesel. In thin grass on a smothe field I can run in 6th. I normally run in 5th but hace had to run in 4th in really thick stuff.
I have a 2510 gas and it will not handle my 8 ft.
disc mower very well. In heavy hay on hills, I need
to go to 4th gear. It gives it a load.
A JD 275 will be a load on a JD 2510 on the lifting side. You will also have a lot of side draft for that tractor.
Just check the cutter bar out for loss gears and or hard turning ones. They can be costly to repair.
