Still trying to learn how to rake hay with an old Bradley tail dragger side delivery rake.
Just raked a hill side that was steep enough that I raked everything vertical or up and down the hill. Made baling much nicer but leaves dead time in going from row to row to bale.
So what do others do on a hills where there is a pucker factor of not feeling comfortable going across the hill side ways?
Also when rake a flat field and you go continuously around the field to the center, how do you get out of the center without messing up everything you just raked? Understand with a three point rake, but for anything you tow it seems like there is no good solution for getting the rake out of the center of the field.
