I am going through my Great-Grandpa's mower to get it back in working order again. It had sat and the wheels were locked up on from sitting. All that is taken care of now and I have 3 questions.
1. The small gear shown in the closeup pictures it appears there are supposed to be 12 ball bearings that the gears spins on, however there is only 1 left in it now. I have ordered the ball bearings but we could not get the gear off of the shaft to put the bearings in. Does not appear to be a key that we can see. If not we will have to grind some of the casting with a notch to drop them in.
2. In the last pictures there is a bolt that goes through the tongue with a spring on it. Can anyone tell me the correct location of this and what this spring does? We had it off and the levers/foot lever worked pretty well. Then I remembered the spring as we thought it would assist in lifting the sickle but with the spring on it lifts the sickle, but then does not let you drop the sickle lower for mowing. The old tongue had a hole drilled in it for the bolt so that's why we remounted it there.
3. Last question, where would a person find the correct color orange to paint this and then a good picture to get any other coloring right on the mower? I want to use it first some then start painting it this year or next year.
I will attach links to a photobucket album for viewing of the pictures. If not email me and I can send them to you - thanks for any help!
Photobucket Pictures Sickle Mower
