sickle mower question
Chief 83
A friend of mine has a sickle mower of unknown brand. I'm sure though if it had a brand on it, it was probably made in another country. It is new. I think he got it a payment on a debt--
He is now trying to hook it up to the 3pt hitch on his NH tractor. I don't think it is a 3pt mower but have no idea how it should be mounted. It has in a triangle shape U shaped connectors that should have a pin go through them. the 2 on the bottom (where it would appear 3pt pins would be on a normal setup are spaced at about 32 inches. Too wide for 3pt. Even if you got those connected some how the what I would say is the top link mount would be a the same height so pretty much going straight down. That of course wouldn't work as it would block the drive shaft. I'm thinking he got screwed and is missing a bunch of mower. I just have no idea what those parts would be??? Oh and he got a "rake" with the deal also. It's not too bad, also new and I think it will work fine. Problem is it is not a rake. It's a tedder. Nope, not a combo unit strickly a tedder. The real sad news here is I'm probably going to get stuck doing his hay. It's only a small piece but rough as a cob. Doing my best to get him what he needs to do it himself.
