so i bought this new idea 290 haybine from my aunts husband. he had used it for a short time then it broke the bar close to the end that mounts to the (wobble box?). he bought a new bar and it did the same. he thought something looked miss aligned so he shimmed the bottom block that the wobble box shaft attached to the body. but obviously didn't help... so i bought it for 400 bucks and dragged it home. i pulled the wobble box off. first thing i noticed was a ton of weld where the main shaft meets the short tube that the Z shaped bar is welded to. it didn't take long to see that that repair was made and it was twisted making the main shaft off a few degrees from the shaft that the cutter bar attaches to... they are not parallel and it would seem to me they should be. from what i have read is that this 290 is the same as a ford 535 and the MF 81 models... does anyone have one of these that can take a look at theirs to confirm? or anyone just know? and then the question would be what should i do to fix it... try to grind the ton of weld to straighten it there or cut out the Z bar and adjust it there or just try to heat the Z bar and tweak it there? i know posting a picture might help, i'll try to take a couple tomorrow.
