Disc Plow blades
Jason_VDB
I am looking for at least 1 or up to 3 disc plow blades for a Minneapolis Moline TRA or TRB. If anyone has a lead on some I"d appreciate it.
Some of the bigger discs have similar size and dish. You have to know the diameter you need, and the concavity.(lay a yardstick on top of upward facing disc, and measure at center) Then go to agrisupply or shoup, and see what's available. Then you will need someone with a plasma cutter, to cut out the mounting bolt holes...
I took on of my old blades into the store and matched it to a new disc blade. I would recommend a plasma cutter for the holes you will need to add.
