Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Tightening Round Disc Gang Bolts
Dick2
06-27-2014 10:49:26
Secure the shaft so it can't turn (pipe wrench on spacer), then tighten the nut on the shaft. When you think that you have the nut tightened enough, hit the discs with a hammer - if the discs don't ring, you need to keep tightening the nut until the discs do ring! There should be some kind of keeper on the nut to keep it from coming loose, but getting it good and tight is essential.
Tony C.
06-28-2014 10:14:13
 Re: Tightening Round Disc Gang Bolts in reply to Dick2, 06-27-2014 10:49:26
I thought holding the spacer with a pipe wrench only works for square bolts, not the round ones.
For round bolts I usually try to hold the bumper with a wrench and then tighten the nut; might take a 2nd person. Check it every few passes in the field until it won't tighten anymore. I take the wrenches out on the tractor with me. A good thick nut with more threads than a hardware store nut helps too.
As far as his disk having round bolt in square spacers, maybe bolts were replaced in the past.
vernon in ks
06-27-2014 11:18:40
I will add if they are loose enough that dirt has gotten between disc and spacer you will never be able to tighten it enough until its cleaned out.
JMS/.MN
06-27-2014 11:29:53
 Re: Tightening Round Disc Gang Bolts in reply to vernon in ks, 06-27-2014 11:18:40
Yup- dirt grit turns to powder and the discs are loose.
Copyright © 1997-2015 Yesterday's Tractor Co.
