Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: What kibndof hyd fluid to use in 852 NH R Bailer
old
06-27-2014 07:48:00
If that is the case 303 UTF is fine
ryanwheelock
06-27-2014 08:01:13
 Re: What kibndof hyd fluid to use in 852 NH R Bailer in reply to old, 06-27-2014 07:48:00
old have you ever got a chance to mow any hay with your BA? Looked like neat set-up when I saw the pictures a few years back.
old
06-27-2014 08:09:20
 Re: What kibndof hyd fluid to use in 852 NH R Bailer in reply to ryanwheelock, 06-27-2014 08:01:13
Mt BA is what I mow probably 99% of my hay with. Turns on a dime easy on fuel and rides good. Only problem is it can be hard to get on and the hand lift of the sickle bar is a tad hard. Been thinking about adding a power steering pump to it a control valve and a cylinder for the lift. It is sitting in the hay field waiting for a week with 3 days that the weather guesser say no rain
ryanwheelock
06-27-2014 09:06:13
 Re: What kibndof hyd fluid to use in 852 NH R Bailer in reply to old, 06-27-2014 08:09:20
Nice!! Love the looks with the duals on the 1 side!! Neat little rig you made up!!
old
06-27-2014 09:59:47
 Re: What kibndof hyd fluid to use in 852 NH R Bailer in reply to ryanwheelock, 06-27-2014 09:06:13
Ya figured I need the duals on the narrow side to keep from flipping it over and then once I put them on I found it made it look sort of neat also. You do notice the sickle bar on it and that it is down in the mowing position. Also the exhaust pipe is not the run of the mill type of pipe. The exhaust pipe is a copper pipe instead of the normal steel pipe
