Bryan Rubingh
New User
This message is a reply to an archived post by Bob on August 31, 2008 at 11:11:01.
The original subject was "Re: jd24t crank bearing".
I did a bunch of digging because i had the same problem with my 24t. That is, the bearing on my 24t baler on the pickup side went out. Note that this bearing is only for balers with serial numbers less than 32000. JD wants $135 for that bearing! I thought that was ridiculous and set to find a substitute. Found out a BCA 88509 is the same bearing as the JD7140. I looked at a bunch of other bearings and i don't think other manufacturers 88509 are the same. Not certain on that. I've ordered a BCA 88509 from ebay for $22. Note that the 88509 is available from autozone as it is used in a bunch of cars and trucks. One could probably go there and ask them to look at one or supply dimensions.
