Turning 4 bottom plow to a onland hitch
I won't say no, but typically you had to get to 6 bottoms, or at least 5 big bottoms, before the geometry was right to allow the tractor to be up out of the furrow and still able to pull the plow straight. A plow wants to kick over to the left, one needs the tractor centered proper to compensate for that which tends to put the tractor a little to the right, not allowing room to be on land on a smaller plow?
Paul
My brothjer were discussing this trying to get out of the furrow because we have springs here , When hitting one we always need to pull the plow out with a chain we break thru and its like quik sand I seen some 4 bottom melroes for sale on tractor house that were set up for on land
As Paul mentioned going to a huge side draft with that small of a plow. Just need to use a tractor that is heavy and big enough to muscle it thru regardless of the side draft.
