Yesterday's Tractor Co.
Shop Now View Cart
Re: IH 800 Air Planter - Help Needed
06-12-2014 17:51:09
Marker box lights up and changes from left to right when advanced is tripped. Ground wire was on a freshly filed face. Any thoughts on why the planter will not lower with the tractor running?
06-12-2014 18:59:52
 Re: IH 800 Air Planter - Help Needed in reply to jmandrze, 06-12-2014 17:51:09
If you shut the box off and then turn back on will it work? Hold the hyd. lever on the tractor in the lift position for a few seconds with tractor at high idle to maximize pressure output. May just be your pump is not good enough. I was told you could get a less pressure switch for older tractors, like 1500# instead of 2000#. Something like $125.
