I have one of these and am using to cut a little hay. I got it working good and it cuts good. I have it on a kubota or JD 2240 as it is PTO and 3 point moounted.
My question is that in cutting mode with the bar down horizontal I cannot lift the bar much higher than 5-6 inches off the ground even with the lift arms all the way up. Is this normal? It would seem you would want a little more height to clear any rocks or potential obstructions.
Thanks for any helpful info.
