10' lift disk identification
Ok my dad has a 10" lift disk and I was using it today and the front left disk gang the final nut and spacer block fell off and I lost it. How can I identify what kind of disk this is so I can try to find a new nut and spacer? I think I can make a spacer but I am trying to find out what size nut it is so I can order one. Is there anything I can look for on the disk to identify? I think about 10 years ago I used the forum to get a new bearing but don"t recall how we identified it. is there anywhere to get parts? thanks
Look for a logo on some of the castings ie:IH ;Case eagle' JD......The nut is probably just a standard 1" or 1 1/8" coarse thread nut.Just measure the shaft/thread diameter.If you have to,remove the nut from the other side.Take it with you as a 'sample'.About any spool/spacer will work.Or as you said,you could make one.A pic(s) would help.
