Dave H (MI)
I ran thru some of the ideas y'all have thrown my way. Headed out hoping to put it onto the field but I could see from the road the dark half circle in the field where it joins the lawn and it is just a bit too wet there still so I am going to wait a day. I played with the pressure control valve a little and actually picked up almost 2 oz. Brings me to about 5 oz with the drum loaded. Turned the drum so one row went under the rollers. Eight seeds hit the ground behind the planter. Behind the planter I have a pretty good breeze coming thru each tube. So I lowered the planter to just above the ground and rolled the tractor forward. Result was 8 rows with good spacing. Time to give it a rest and get it done! You guys were right....it IS working. Thanks for all the help!
